DL06 won't communicate
BitHammer
Mar 2007
Chicago area
I can't get a PLC Direct DL06 to respond via serial link. The RX1 light flashes, but the TX1 does not.
Is there any way to hard reset this beast?
Thanks.
Only a software reset. Do you have the correct cable. The RS232 requires a jumper between rts and cts. Otherwise a protocol or address failure. Use the auto detect function of Directsoft.
Got it!
Thank you for the response. The problem was the driver for the USB serial port adapter. I did find out the hard way about RTS/CTS jump, though!
Hi, Mostly AB guy here with a little Koyo experience, but all of its digital. I get handed three analog I/O cards and asked to prove that they...
509
Hi all, I am making a test rig to be able to wire in any DL06 (or DL05) And create a HMI in red lions crimson 3.1 to test all the inputs and...
940
I have a Cmore screen which is communicating to the DL06 in BCD and need to create a timer that works in real numbers for a test, I simply need to...
2,168
I have a client that has many Automation Direct DL06 PLCs for a municipal water/wastewater system. When there is a power outage, one of the sites...
2,456
Hey everyone, Working on a system with a Koyo DL06 processor and it's my first experience with them. I have DirectSoft 6 and we got the program...
2,370
