Dnet slave in a 1756 chassis
jdbrandt
Oct 2002
Pennsylvania
1,203
Is there a solution to make an AB 1756 chassis (rack) a DeviceNet slave on a DeviceNet network?
The 1756-DNB appears to be 'only a scanner'.
None of the large chassis-based I/O platforms (1756, 1747, 1771) from Allen-Bradley have an Adapter mode on DeviceNet.
Two of the small distributed I/O platforms do; 1769 Compact I/O, and 1734 POINT I/O.
The 1756-DNB can be a slave device, but it needs a controller to exchange data with; it cannot directly bridge CIP connections to other 1756 I/O modules.
Hi All, I am looking for some advice regarding the correct steps that should be taken if I was to replace an existing (but now obsolete) Third...
2,655
Hi everyone! I am newbie here so be kind) I have some m340 plcs in one network and one TSX quantum, that reads data from them via io scanning...
1,465
Hey ya'll and Ken if you're out there, I've encountered one of the strangest dnet issues I've ever come across. I have a Rockwell estop box...
1,671
I have an old SLC500 that I will be upgrading to a CompactLogix 5370 or 5380. I can put an ethernet card on the 1746 rack and treat the I/O as...
1,733
Hi! I have a PF700H, 600V, 590A. Its on DeviceNet. Produce Type: 121 Product code: 45620 Revision: 1.006 EDS File I think I need...
1,457
