Turbo,
I have interfaced Automation Direct PLCs to HVAC systems. For HVAC systems with 24 VAC controls, I like to use one of the DL-105 units that have actual 24 VAC Inputs and Outputs. For example, the flollowing DL-105 PLCs all have 24VAC inputs: F1-130DA, F1-130DD, F1-130DR, F1-130DD-D, and the F1-130DR-D all have input terminals X4, X5, X6, X7, X10 and X11 as dual 24VAC/ 24VDC inputs.
The F1-130AA, F1-130AR, F1-130DA, F1-130DR, and the F1-130DR-D also have output voltage ranges that will accept 24 VAC.
Therefore, looking at the overlaps, F1-130DA, F1-130DR, and the F1-130DR-D all have six 24 VAC inputs and 24 VAC outputs. The ones with an "R" have relay outputs with voltage range of 12 to 250 volts AC and 12 to 30 VDC.
You may want to consider swapping the DL-06 for one of the DL-105s, if one has enough I/O for your job. Heck, at $159 each, use two of them! That would give you twelve 24VAC Inputs and 16 24VAC outpus! You will need 120 VAC for powering the PLC itself.
Before someone jumps on and says the inputs are only rated for 24 VDC, be sure to check the Specifications, not the brochures, before you tell me this won't work!
F1-130DR - Wiring diagram and specifications
Power Requirements
Voltage range . . . . . . . . . . . . . . . . . . . . . . . . . . .94-240 VAC (30 VA), 100-240 VDC (30 W)
DC input specifications
Number of input points . . . . . . . . . . . . . . . . . . . . . . .10 (sink/source)
Number of commons . . . . . . . . . . . . . . . . . . . . . . . . . . . .3 (isolated)
Input voltage range . . . . . . . . . . . . . . . . . . . . .(X0–X3): 10-26.4 VDC,(X4-X11):10-26.4 VDC or 21.6–26.4 VAC
Input impedance . . . . . . . . . . . . . . . . . . . . . . .2.8 K@ 12-24 VDC
ON current/voltage level . . . . . . . . . . . . . . . . . . . . .> 3 mA / > 9 VDC
OFF current/voltage level . . . . . . . . . . . . . . . . . .< 0.5 mA / < 2 VDC
OFF to ON response . . . . . . . . . . . . . . . . . . . . . . . . . . .X0-X3: 50 μs
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .X4-X11: 2-8 ms
ON to OFF response . . . . . . . . . . . . . . . . . . . . . . . . . . .X0-X3: 50 μs
Fuses . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .None
Relay output specifications
Number of output points . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .8
Number of commons . . . . . . . . . . . . . . . . . . . . . . . . . . . .4 (isolated)
Output circuitry . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Relay
Output voltage range . . . . . . . . . . . . . . . . . . . . . . . . . . . .12-250 VAC, or 12-30 VDC
Maximum voltage . . . . . . . . . . . . . . . . . . . . . . . .265 VAC, 150 VDC
