Do we have any standard / regulations / PM for SCADA !?
leonlai
Jun 2011
WA
96
folks,
I always have stupid questions because learning is never enough and i'm not an experts, plz dont judge !
Do we have any standards / regulations or preventative maintenance for SCADA out there !?
I looking around for sources (mostly internet) but cannot find a standards,
look like more about IT network securities more than a (anything related to) SCADA (regulations,standards or Preventative maintenance)
Because I always think that one a system is up and run fine/good, it's suppose to run like this till the life time of a PLC / modules / components, right !? So we only stocks parts (PLC,modules) in case system fail !?
Is there any sources / info !?
btw, is there any good magazine for SCADA/PLC like us to continuing learning/ updating knowledge !?
Nope, but you treat it like anything other maintenance task.
If you are running a HMI that only runs on Windows 2000 then you need to come up with a strategy to replace the box if it goes up in smoke or upgrade the software and box to run on newer OS. Either option works but you should have a plan and/or part in place.
Good advice and I would take it one more step and say that you need to have the plan implemented before it becomes an "Emergency" which doesn't get enough time to implement 'properly'.
After some interesting conversation regarding the safety of emergency stops, I saw some posts talking about the safety standard conversation...
26
978
I have programmed servos from a handful of variety of manufacturers and series. Each time I used a PLC without motion functions. I have not worked...
772
Hello, I'm am engineer for a plastic manufacturer. We swapped out a oem motor with one of equivalent nameplate stats made by marathon on our roll...
503
I am trying to implement a sfift-by-wire on a vehicle and for that I am using a standard servo motor...
334
Had an interesting experience this morning. An old Panelview 600, 2711-K6C5X series B to be precise, comes up as error 32. Unfortunately it...
221
