Does anyone recognize these terminals?
Bit_Bucket_07
Feb 2013
Southeast US
1,875
They are installed in a control panel that was made in France and are intended for the termination of analog inputs. Each of the red capped pigtails land on an adjacent ground terminal, but these ground terminals won't tighten effectively onto a single shield drain wire. I am unsure of how to properly terminate our wiring onto these terminals.
Any help would be greatly appreciated.
They are - was Entrelec, was ABB now TE Connectivity, though they seem to be a mix and match between ranges. The darker grey fuse terminals are from the older 1SNA range:
The lighter grey are the 1SNK range:
page 76 shows the terminal with the earth prong sticking out, though I don't remember it from the catalogue.
My interpretation: panel builder error. The pigtails should have been connected to the other side to ground the terminals, freeing up the field connection side for your shields to connect with a crimp terminal where the ground wires are now. Is anything connected to the other side?
double up the wire; strip 2x what you need, fold it over on itself, twist a few times for good measure. Also, could use a crimp-on type of ferrule, much more time consuming in my limited experience.
It's off a pallet positioner that doesn't have a name or model number. The body is all plastic. I epoxied it back together but that probably won't...
4,389
I have a project to changeover some power supplies that the present ones are powered with an AMP plug & receptacle- see the attached picture. I...
2,183
I'm trying to help with an asset inventory for a plant we might be taking over. All I have to go on is this photo. I've tried searching through...
2,743
Need some help here (again). I tried to download my HMI to the PLC and I get this error message about a missing file. Can anyone help?
820
Hi there, I need to work on a GE series 5 PLC which need DOS based Logic Master 5, it seems like nowhere I can purchase this software anymore...
955
