Dosage pump
MrQ
Feb 2005
236
Hello,
All dosage pumps I have ever used has a 4-20mA command signal and seperate supply.
Now, the customer has a pump with a 24 Volt DC motor. Speed is to be controlled by varying supply voltage 0-24 V. It's a small motor and I have not yet found out the current but it is low.
So, I need some way so that a 4-20mA or 0-10V signal from my PLC can control 0-24V to the motor. Ideas???
Basically the same way you'd control a 90V or 180V DC motor. There are 24V versions available. For example, THIS ONE from Dart will do 0-24V, and accept a 4-20ma control signal (with an option board).
-Eric
Hi All I have Dosage pumps with 145 pulse/minute at max speed. at that point flow is 48 l/h @ 50 Hz. How do i calculate the volume per pulse...
2,133
Hi i have a dosage pump with rate that can be adjusted between 12 and 125 impulses per minute . i want to operate it externally with 2...
2,734
Hey there guys, I'm relatively new to PLC programming. I had a few basic classes in college but since then I have mainly been on the instrument...
143
106
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
148
