Downloading a cde file
archy
Jul 2014
California
52
I am working my way through the 900 Station Designer User Guide and it appears to jump right over how to download the cde file from my laptop so that it will be available for import. Could someone please tell me how to do this?... Wait, it needs to import from the HC900 so I must be failing to communicate with the device...?
... no, I think the display should be able to comm to the device because I can download to the HC900 through the same switch that the 900 is connected to. I believe all my addressing is correct. I'm trying to get the "Create Data Tags" to light up under Communications - Station Network - Protocol 1 - HC1 in my 900 Control Station software.
...nevermind. It was because I didn't duplicate and rename and download a unique sds file. "Create Data Tags" is lit up now!
I am kind of new to GE products, but we have several in my area. I made a minor logic change and it verified good, but when I tried to download I...
43
I have a L82 system setup redundant that i need to download a lot of programs to in a critical environment. What is the process to do this and...
317
Hello everyone, I am trying to upload some parameters from a powerflex 523, and download them to a new powerflex 4. First problem is I’m not...
613
When I download a hardware configuration using the step 7, it first asks me to select the target module. Only option that is offered is the CPU...
1,220
Hello, I am attempting to download a program someone else created to an existing PLC (1769-L24ER-QB1B CompactLogix5370 Controller). However, when...
1,109
