Downloading a program to a touch panel
Shohadawy
Aug 2008
Egypt
66
I'm using an Exter T100 touch panel and this is the first time for me to use a touch panel so I want to ask the following newbie question :
Does downloading a program from the PC to the panel requires connecting it to the power supply ... or the power supply is needed only while running the application?
Yes, in order to be able to download an application the unit will need to be powered up. If you download the application over an ethernet connection make sure that the terminal and PC are on the same subnet.
Another options instead of using a cable to make the transfer is to use the 'Export Project Transfer File' in the Transfer menu. You can export the file to a USB stick or Compact Flash card, you then connect the stick/card to the powered up HMI and say Yes when asked if you want to load the program. I find it easier than using a cable. If you are using a Vista computer make sure you run the programming software as administrator or you may hit unexpected and strange problems
Bryan
Hello, I am attempting to download a program someone else created to an existing PLC (1769-L24ER-QB1B CompactLogix5370 Controller). However, when...
1,109
Hey guys, So I'm adding a new HMI alarm and so I had to update alarm text in winCC. I compiled and went to download and get an error for...
1,614
HI We have a mdv60a0110-5a3-4-00 and mdx61b0110-5a3-4-00. how can we transfer (program download ) mdv60a to mdx61b? best regard
952
994
I have 16 cb_E connected to OP16 via fiedbus and the cb-E connected to l60 controllogix via en2t ethernet. using generic module in IO config so I...
1,735
