Downloading the project
cakkostepen
Oct 2005
İstanbul
31
Hi guys,
I have one PLC one Simodrive and an OP which I should connect all three of them. I have set two profibuses and simodrive is connected from one of them OP is connectes via the other. One of the connecters I use to login the plc lets me to connect my laptop at the time with the OP. When I download the project to the PLC, it stops in 25% and it says "downloading TP CAM". It doesnt proceed from that point on. Can anyone suggest any solutions?
PLC is Siemens' SIMOTION C (basically a s-300 for motion control systems)
Software is SIMOTION SCOUT
While downloading a window informing about the process appears in there the msg appears
I dont know Simotion Scout software, so I may be on thin ice.
In most Siemens error message there is a "details" button that will provide more info about the particular error.
Also, try to disconnect the drive and the OP when you are downloading to the PLC.
If the download is via MPI at 187.5k, it may be an idea to download via DP at 1.5M.
Is CPU configured for profibus already?
cakkostepen, unless the CPU is already configured for profibus, you will have to go through the MPI port and configure the hardware. Once this is done you will be able to use profibus to load your program. Also, I was wondering why you didn't wire all devices to the same profibus. As stated earlier, there is not enough information to answer your question.
Tech7
this is how my system is set.
and this is what I get while downloading the project
Is it possible that I have to wait more than 30 minutes for the downloading process
Hello everybody, I have a problem with TwinCAT 3. When I try to activate a configuration and start IPC in Run mode I receive an error AdsWarning...
5,708
Hi, trying to use the USB autorun functionality of the HG3G to download a new WindOI-NV2 project file into the HMI. My project file extension is...
3,374
Good day, may i ask if downloading the project in proface hmi GP3000 series is that simple,in transfer tools using "Send Project"?and when i want...
1,897
Is there something that I can programmatically do to prevent motors from starting when downloading?
4,374
Hello, I have been asked to handle a mission impossible and need help from you all. My previous engineer handed me a Schneider HMI (XBTGT7...
2,119
