DPRD_DAT, DPWR_DAT what are the restrictions?
bara_hence
Aug 2007
Ockelbo
225
Ive had troubles in the past reading data using the SFC14 and writing with SFC15.
For example tried reading and writing to a watson marlow pump wich had this setup (Se attached image)..
I read 12byte to a 12byte long structure and write from a 6byte long structure.
I never got this to work so i had to use direct access instead..
So I wonder if there is any more restrictions than that the are to read/write must be 3bytes or larger than 4 bytes long?
I will get my hands on a pump later this year (dont know exactly when..) and I will try again..
The last time we had a hurry and I didnt note the error codes.. But this time around I will have some more time at my hands.. So then I can post the error codes..
I will post the code use last time later this week and the new code that will be used this time for interfacing the pump to..
I made some cleaning up in the code in the spare time..
Hi all, I have few GB of logged data created by RS View 32 Works, it is all in .DBF format. At the moment, my company wants to shift all data to...
1,469
SFC 14 and SFC15 giving error : -32591 I am using the library from ABB for the drives to run ACS800 from S7-300 CPU(6ES7 315-2AH14-0AB0)...
958
Hello, Is it possible to use the RS logix 500 software to mimic any type of commands that the 1764-DAT unit on the ML1500 plc uses? I have a...
1,225
Hey, Iam trying to open an E-Designer project. I don't have the .mpa file. I only have .dat Question is, how can I restore the .dat file? Do I...
2,782
Hi What are the rules for choosing a heidenhain EnDat encoder? I have a broken encoder on my Baumuller servo motor need to be replaced...
1,377
