dps2-splitter "prog/hmi" problem
dialc
Jul 2009
Montevideo
I am have some problems using a 1747-dps2 splitter and perhaps you can help me.
I have a slc5/04 connected to a HMI via the com0 (rs232) and now i want to connect a pc to program the slc5/04 via com0 at the same time the hmi is connected. To do that I get a 1747-dps2 splitter so I be able to use the programmer and at the same time the hmi.
Testing this I get the following:
- with the HMI connected to the network port of the splitter and the slc connected to the controller port everything work ok (nothing connected to the prog/hmi port).
- with the PC (using rslinx) connected to the network port of the splitter and the slc connected to the controller port everything work ok (nothing connected to the prog/hmi port).
- with the PC (using rslinx) connected to the prog/hmi port of the splitter and the slc connected to the controller port I can communicate to the slc5/04 for a moment and then I lose the connection, then I see the slc5/04 again, and then lose the connection, and so on.
- with the HMI connected to the network port of the splitter, the slc connected to the controller and the programmer connected to the prog/hmi port, the communication between the hmi and the slc work ok until I try to connect to the slc using rslinx, when I do this the communication hmi-slc get lost and the communication PC-slc is get and then lose as described before.
I don't use autoconfiguration in the rslinx.
All cables are null-modem
Someone knows if this could happend when the switches of the dps2 splitter are bad configurated ???
Thanks in advance for any help.
I have a maples Blue series HMI connected to a ML1500 through a 1747-DPS2 port splitter I also have a 1761-net-eni connnected to the port splitter...
3,002
Customer has a SLC5/04 communicating with a PV600 via DH485 thru Channel-0 RS232 port. Wants to add another HMI communicating over the RS232...
11,527
Hello all, I've utilized many threads on this site and gleaned much information throughout the years. Now the time has come for me to finally...
1,790
I'm connecting up two remote ethernet devices to the switch in my control panel, and I'm trying to do the cleanest install. The customer typically...
596
Hello everyone, I hope all of you are doing well through summer and staying hydrated. I am going through a sort of a mysterious issue. We are...
859
