Drive Explorer
lifetech
Dec 2012
Arcade, NY
39
I have a newer laptop that does not have a serial port and I need to have the ability to connect to powerflex drives using the drive explorer software.
I found a USB to SERIAL adaptor laying around here but it still will not connect. I thought I read somewhere that not all usb to serial adaptors will work with all AB software.
I was wondering if anyone has used an adaptor that works with Drive Explorer, and if so, what is the make and model number?
Thanks!
If you ARE using USB --> Serial converter verify your device settings in Device Manager for the COM1 port settings (Baud / Parity etc)
Bernie is right. If he has a 1203-USB then he will not need a USB-Serial device as this is a USB connection.
The older adaptor that I have does require a serial to USB device such as the Keyspan. I am not sure of the model number of that particular adaptor as my old adaptor looks like it has survived a few major wars.
Can anyone point to an explanation of the meaning of the green/purple colours when using Drive Image explorer ?
2,283
I am trying to configure the parameters of a 22-COMM-E Ethernet/IP Adapter (inside a 22-XCOMM-DC-BASE) with Drive Explorer over Ethernet. I can...
3,155
Working at our sister plant today and tring to help them with some backups. They have drive explorer V6.02.99. I can't seem to find a users...
3,835
Hi, We have a customer plant running PLC 5 with Flex IO and one PowerFlex 4 & one PowerFlex 700. They alreay have Drive Explorer V4.04. 1) The...
6,389
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
321
