It is a simple as running the install file for all Citect drivers. I would suggest you then re-boot the computer.
I would also suggest you haver a good look at the driver help - it sounds like you do not have the driver set up correctly in your addressing in Citect.
If all else fails, ring Citect support - they are very good.
