driving a servo motor on omron cp1L plc
sysin
Jul 2008
Manila
i am new member of the electrical team of our company and as task i was incharged of the controls of an urgent project..one of my problem was how to drive a servo motor on a cp1l omron plc..wat command must i enter, since cp1l's output is relay..pls help..
To use the CP1L's motion functions (PULS, SPED, PLS2...) you need the transistor output plc, not the relay type. Relays don't like giving a 50KHz pulse train :rolleyes:
re:)paraffin power..but my plc is relay output
omron cp1L plc is a relay output plc..s der a way to connect a servo to ds type of plc?..cant the servo's controller/indexer help me on this problem?and so u mean dat i nid a special programming when it comes to servo,ryt?how about ordinary motors,do i need a special programming too wen i connect it to the plc?..tnx in advance:)
regards,
erika (sysin):)
you need high speed pulse(PTO/PWM) to control stepper/servo motors so you really need a transitor-output type PLC. What is the brand/model of your servo motor?
re:)beckz..
the servo motors are panasonic PAC-MV series with 25 hp..can the PTO/PWM help me in this in problem?anyway the motor is only running @ 90 rpm..
What do you want the PLC to do to the servo motor, control what, start, stop, speed matching, move x amount?
I've never seen a 25hp servo motor.
re:rich1955..
i mean 25W only..the servo motors are speed controlled, it will be attached to a conveyor belt, in which items will be loaded..the plc will basically start/stop the motors..anyway, there is no sequence of motors involved in this programming..
regards,
sysin
It is difficult for anyone to help you when the motor/drive specification "Panasonic PAC-MV" does not exist on the Panasonic Automation website. The smallest sevo motor they make is 30W but you say you are using a 25W unit.
If you can be more specific about the unit you are using [post a link to the motor and drive] and exactly what you are trying to do then you will get useful feedback to your questions.
S--- in S--- out.
o_O
re:bits n bytes
but the it does exist in their catalogues..it is a speed control motor, gear type..actuali, the motor is hard to find on the net..anyway, i wil post the specs of the servo motor we will be using:
80A, 25W, 200V, 1.5 kg, 90 rpm..
We have a handful of nearly identical flywheel-driven machines. About a year ago, we installed a 15HP Powerflex 525 drive in simple V/Hz mode...
889
Is there any issue with running a VFD-controlled 3-phase induction motor in torque control mode in the braking region continuously (back-driven by...
4,061
Hello everyone, we're trying to get some information from our screwdrivers. - The control chain is IqR plc with RD77MS16, connected to MR-J4 and...
839
Hi All, trying to restore a runtime application that i have been reliably informed was created in version 10 ftview, i get the below error:-...
996
This is the tab order I have in the e-sign component in Rockwell. Is it set in stone can this be modified? The ideal set up would be to get to...
1,290
