Dururs PLC -Counters
Jan 2014
Coimbatore
Hi everybody,
I'm using a Durus IC210DDR012 PLC Controller. I want to count the number of pulses produced by the Hall Sensors present in BLDC motor. The time period of the pulse produced varies from 4milli sec up to 65milli sec. I am facing a problem in choosing the right counter mode and wanted to know whether this PLC is capable to capture these pulse.If possible how do I do this?
Thank you
the outputs of the hall sensors need to be higher as 10 volt (normal is only 5 volt.
you will need 2 hall sensors to see direction of rotation.
the counter is normal, however you need only a count when the sensor is changing state.
so if A goes up and B is low count +
if A goes down and B is high count +
if A goes up and Bis high then count -
etc. 8 lines total.
etc. 8 lines total
Thanks a lot for you rply.. Im new to this PLC programming . can u pls explain me a little bit deeply so that ill be able to program .I have highlighted the part u had sent. I want to basically control the speed of the the BLDC motor. will you pls help me out with this??
Hi there , when I trying to do some communication things with PLC , I think I made a mistake and now PLC has fatal error. Only error light turn on...
Hello, fellow PLC enthusiasts, I’m a newbie in PLC and am currently on a project that involves connecting an Omron CP1E (CP1W-CIF11) PLC to an...
55
Hello, I want to connect the Factorytalkview ME with rslogix500 to see the live response of HMI buttons in Rslogix500 ladder code . I am using PLC...
79
I have a cell with a compact guardlogix as the plc and I have three hmi's and two vfd's on this cell. I been experiencing momentary comms faults...
131
Hi, hope you doing well I am looking for SIEMENS PLCSIM equivalent in GE FANUC PLC, RX3i PLC thank you
44
