E/H Promass 100 Totalizer Reset on ethernet i/p
My understanding is that they have two ethernet ports one for configuration and the other one for EIP. The one for configuration i guess is the one to be used to handle totalizer reset.
From Endress manual: The address line of the Web browser, e.g. http://192.168.1.212/basic.html.
A fully functional but simplified version of the operating menu structure
starts in the Web browser.
Been a while but I seem to remember some "clear" type bit in the AOP structure you set.
On the promass 100 on ethernet ip. The totalizer is cleared by putting the totalizer control number from the config instances into the totalizer control in the output instance.
For my application it was 198.
So to clear it i moved 198 to output then moved 0 to it when it cleared.
The promass 83 i had used in past had a actual reset output.
How is it going y'all? So We have had a pesky problem with an EH 300 flow meter. We are using EIP to reset the totalizer, and for some reason the...
796
I have a project including S7-300 CPU 314 2PN/DP and this CPU will communicate with Promass 83DP. I tried to connect the flow meter through the...
2,903
Hello All, we have several ethernet IP promass 83 flowmeters from Endress + Hauser in our facility that we use to measure how much material we...
2,395
Does anyone have any insights on how to use these meters with Ethernet/IP? The values on the input table look fine, but I can't figure out how to...
5,705
We have a E&H Promass 83 measuring the outflow from a liquid sugar tank. It has a pulse, 4-20 and two relay cards fitted. we now only use the 4-20...
2,723
