Easybuilder Pro questions
manin
Jan 2015
Athens
37
Hello, I a newbie at plc programming...
I have some questions about easybuilder pro...
1. What is difference between pro and easybuilder 8000? Easybuilder 8000 is newer or older?
2. I am trying to insert some libraries into easybuilder pro, but it always asks for plb files...All libraries I see are flb files.
3. Is there any object to measure temperature by default, or I must build a new one?
4. Is there any way to bring an HMI screen in front using plc DI? Like having an error screen?
That's all for now...Thank you :)
1. Plus is the newer version which covers most of the current HMI's. 8000 is the older version used for some current models, but mostly older ones.
2. The .plb files will be located in your \EZPlus\library directory.
3. No, because there is not any standard for the values. You will have to create your own.
4. Look at the popup windows section in your manual.
OK. I use easybuilder pro.
I have a simulation problem..
When I build my screen, I compile and run simulation, I always get an error message that HMI port (8000 or any port I have tried) is occupied.
I run a port viewer and noticed that port 8000 is occupied, but I have tried many other free ports, and I kep getting the same message.
I run Win 7 Ultimate 64-bit.
I tried to run it With virtual box, and had no problems.
Also to another machine with no problems...
I have this problem for a couple of months now.
Any ideas?
Thanks in advance :)
I have EB Pro installed on windows 11, I can open an existing project and edit but when I got to parameters tab and open page I get the hourglass...
66
Hi, I would like to know if it is possible to modify the properties of an object via a macro? For example I have a value of 100, via conditions...
874
Hi, I'm an intern student engineer and I'm tasked with creating a HMI for a control system in EBPro. I need to make an object (motor) which has...
1,793
Hello everyone Im Newbie to Easybuilder and im designing and HMI application where I gotta display a warning message in a pop up window...
1,816
I am banging my head trying to get EB Pro to convert simple math expressions. Ex: 1 Pump conversion coming from a SCP instruction O0 1.1 value...
1,877
