Eb8000
roxusa
Nov 2008
NJ
994
I have used the Numeric display once before on a MT8070iH and used a 16 bit unsigned integer
N7 then added the decimal point in the Numeric Object Properties Box
My question is if I use a float F8 Would the decimal point place itself.
My display data goes from 1-102 but has the possibility of having up to 3 digits after the decimal. Would I select 6 digits to the right and 0 to the left
I dont have a screen handy to test. Thanks
when using a float, each party knows exactly where the decimal place is.
For the format 999.999 (equivalent of 999 + 999/1000) you choose 3 left of decimal and 3 right of decimal.
make sure you choose 32 bit float as the data type.
Thank you for the quick responce, I had forgot about the 32 bit.
Question if I set up as 3 digits left and only 2 right will it drop the least significant bit.
(I don't really need 3 digits after decimal)
I need a multi state indicator to display based on a register value. I can create it and it works fine my problem is the only one with the most...
1,398
I am new to Easy Builder 8000 although I have managed to write a few screens and put them into use (a lot cheaper than PV+) Can anyone tell me how...
1,533
I found a post asking about RS500 and EB8000 in online simulate and am trying to do the same thing.The post said to shut down RS Linx so it would...
2,282
I downloaded EB8000 for a Weinview Display MT8070iH5, I can successfully download the application but can not get it to communicate with the PLC I...
18
5,022
Hi everyone, I found an information on forum that it is possible to make communication between simulation in RsLogix500 Emulate and Online...
2,863
