EDS File
The communication networks which use the Common Industrial Protocol can interface with very intelligent devices. The EDS (Electronic Data Sheet) provides information to the communication program (for example RSLinx in Allen Bradley) concernig the capabilities of the device including the actual names of parameters, types of data and current values. If the communication program can 'see' the end device on a network it receives a name and also a unique number from the device which translates into the name of the associated EDS file. If the communication program does not have this file it can only report that there is a device with a certain name but 'knows' nothing else. AB's RSLinx reflects this as a yellow question mark. Some newer devices contain the EDS within itself and it can be uploaded by the communication program.
Note that even version number changes in a device will require a different EDS file because of changed capabilities of the device.
As far as 'what you do with it' I can only discuss Allen Bradley. It has an 'EDS Hardware Installation Tool' which will, when given the name and location of the EDS file, distribute the information concerning the file to the appropriate places, including the Windows Registry, and make a copy of the EDS file in a central storage area.
Hey y'all!! I'm looking for an old EDS file, GSE 560. I can't find them anywhere. It is for a GSE560 display on a DeviceNet network, with...
104
Hello, This product that I have the 1790D-T8BV8B is discontinued, does anyone have the EDS file for it? I wonder if TechConnect will have this...
200
Hello Friends We have 10 Powerfocus 4000 with DeviceNet, We need to backup the configuration, the Powerfocus is detected but as unrecognized...
119
Hi everyone: I went to AB.com, found only firmware, no EDs file showing up. i took a pix of device properties of RSLinx. Thanks
138
Hi all. Please can anyone assist me with a Devicenet EDS File or link for a Numatics G2-2 solenoid valve bank. Need to do configuration on a...
723
