Electroless tin plating
rpoet
Jun 2008
New York, NY
536
I used some electroless tin plating solution to tin plate the copper traces on a PCB that I made in a class in college, years ago. The stuff worked great... on copper. Anyone have any idea if it will plate mild steel? I have some small brackets I'd like to add a little corrosion resistance to, but can't justify having them coated at a plater.
I used this, or something similar to it:
https://www.amazon.com/MG-Chemicals...005T8PE4A/ref=cm_cr_arp_d_product_top?ie=UTF8
My inorganic chem is even rustier (pun intended) than my PCB fab skills, and I'm not sure if the chemistry would work to plate steel. I've also looked into electroless nickel plating kits, but they look like lots of work, nasty chemicals, and they're too expensive for this little project.
Thanks,
-rpoet
Been struggling to wrap my head around this all day, maybe someone else has an idea. I've got a pressure sensor connected to a 1771-IFE analog...
637
good morning all I have several red lion da30d using crimson 3.0 on the controls network in the plant. I am thinking about getting the AB power...
2,168
Hi Gents, This is a long shot, but I know you guys can pull things out of the bag. My boss has just bought an old corking machine, a Valentin...
1,304
Hi I am twido PLC TWDLCAA24DRF and HMI HMIS5T . Confugured HMI as master and twido as slave on modbus RTU. Parity none,stop bit1,data bit 8...
1,301
Hallo, I have problem in running runntime application in factorytalk view. After loading the application the application shuts down when the run...
1,557
