Elevator with S7 300???
BluP
Apr 2009
Tu
Greetings,
I'm student and I would like to program PLC for 4 floor elevator in FBD, it will be just simulation, but maybe we'll realize it in college. So all inputs and outputs are on simulator. It'll have this:
- Switches in & out elevator
- Switch on every floor to figure on which floor is elevator
- Door close switch
- Emergency stop switch at top and bottom of elevator shaft
- Output are two digital outputs (elevator up, elevator down)
First problem for me is logic of elevator, how can I make elevator to go where I want. I found this picture http://img83.imageshack.us/img83/976/elevatorw.jpg but I don't know how this mul works? Can you please tell me how can I on easiest way program this movement?
Thank you on any help!
There is a load on here about lifts.... try search facility
Ideas for you
Use integers for your floor numbers (0 = ground, 1 = 1 etc)
Use a integer for current position, use integer for required position.
Then, if required > actual go up, if required < go down
When lift hits floor position switch, move the floor number into the actual position register.
If actual= required, you have reached your required floor.
Maybe have a DB to contain requested floors so you stop if floor is in DB
Dont want to do the poject for you :)
Cheers
Hey guys , I have included a couple attachments here , one of what I was supposed to come up with a program and the program I came up with. Does...
3,152
I've been trying to solve an issue that I've had for several days now and it has now made me give up, which in turn led me to this forum in hope...
2,596
Hi I'm new to plc and I've been looking for solutions in 4 floor elevator. I have been studying this elevator solution for like a week now, and...
2,900
Hello, I'm trying to make a 4-level elevator work in SFC, but I feel kinda lost. Could anybody help me with at least the first 2 level SFC? Thank you
4,296
i am making this elevator program in TIA portal I have written a program but it is not complete yet i created two arrays the first array is...
2,237
