EM 231 Input Ranges
speedcat
Mar 2009
cairo
27
Am Using Expansion Analog Module EM231 On S7200 CPU 222,It's Mentioned In The Manual That You Can Set The Input Range (0-10v,0-20mA...)Using Dip Switches In The Module And You Cant Work On More Than One Range At The Same Time,This Picture From The Manual & Am Wondeing If I Set The Dip Switch On The Range From -5 to +5v,Then If I Connect Input On x+,x- Then I Will Read From 0 To 10v,,But If I Connect Input On Rx,x- (With Rx,x+ Bridged)As Connected In The Picture On The Third,4th Channel Then I Will Be Able To Read From -20mA To 20mA(5v/250ohm)By Doing The math Inside The Program i.e: Dividing Input(volt From -5 To +5)By 250 ohm To Get Equivalent Current Which Should Be From -20 mA To 20mA????
Thanks In Advance
Additional Note My Corrent Source Is A Current Transfomer & Still I Cant Figure Out How The Secondry Winding Load Will Affect The Primary(Power) Circuit Which Is Loaded By A Dynamic Load Of 60 Watt Per Phase
As above. I've been fishing around on TIA portal but haven't found a "Disable channel" tickbox. Is there one? If so, where is it? Cheers
1,343
Hi We have a SIWAREX 231 weighing card controlled via PLC (not stand alone) We have used these for a while with no issues. We can auto and...
1,108
Hello all, I need to know more about this module (siwarex wp231) please How to program and how can i deal with it inside TIA portal (address...
1,462
Hello- 1st off - I don't get involved with many Siemens PLC's here :o: I have a 231-4HD32-0XB0 4 channel analog in and a customer provided...
3,291
hi all.. i am facing SF(red led blinking) in my TWO analog cards,,cards are 1-EM231 AI8*TC PID 2-EM 231 AI8*16 BIT how i can rectify these...
2,715
