Emergency Stop return signal
pedro_nf
Nov 2018
Grenoble
Hi all,
The Emergency Stop button is connected to the security relay etc and cuts the machine power. My question is not about the safety circuit side of the Emergency Stop but rather the information of its state (pressed or released), so I can display it in the screen. Should I use a Normally Closed (NC) contact or a Normally Open (NO) contact? Is there any rules or norms about that?
Thanks in advance,
Pedro
You can also get lighted estop buttons. I like to use lighted buttons with no status contacts.
+1 on g_mccormick's idea.
I used to work in a stamping plant where the automatic presses with feedlines could have up to 11 E-Stops on the line. If one was pressed it lit up, so no one had to walk around checking each one - it was the one that was lit.
I like to use lighted E Stops where possible.
and use N.C. contact back to the PLC inputs. That way I can use the input in the program as a stop command / run permissive and on the HMI to show what E-Stop is activated.
If I don't has all E-Stop inputs on you can't run. Also use it to do any housekeeping I need.
Lighted E-stop button with 2 N.C. contacts for the safety.
1 N.O. contact for the light (on when pressed) and use the same N.O. contact into the PLC if you have one
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
311
Hello, I have plc Schneider TM241CE40T with the hmi HMIS5T. Do you have idea how to disable a button after an emergency stop to vijeo designer ...
1,467
Dear colleagues I am learning to program siemens plc. I have a problem with how to solve the problem with a power outage and emergency STOP...
1,746
Hi, I would like some recommendations/advice on wiring of a dual channel Emergency Stop for a 240V AC motor (single phase), I have 3 options in...
47
13,624
Hi, We have a machine that we wan't to restart after power on if the emergency stop is OK. But if the emergency stop is tripped with the button...
21
6,520
