Encoder calculation in plc
sarathv
Feb 2011
Bangalore
I am using an absolute encoder to monitor the position of motor.
The 12bit encoder is having gray output.
I have a doubt whether to convert the gray to binary in PLC.
Because if I am cutting out motor after encoder counts pulses equivalent to 32mm.Motor output is achieving only 30mm.
One revolution of motor moves 10mm, thatis 4096 pulses.
I am using PROFACE LT3201-A1-D24-C HMI with inbuilt PLC.
Please give a solution,if possible with program logic.
If I understand your problem well you have dead band problem.You "jump"between values.
This is one of the problems of using absolute encoders.
You should go with higher resolution encoder or incremental encoder.
Hello everybody. Can I calculate flow of dust to be pelletized with a configuration shown in the picture? We will take the loadcell signal with a...
7,898
How do i calcilate the diameter of the disk to be used to install a encoder ? Is there a formula to calculate the diameter of the disk ? Lets...
6,071
Sorry in advance for the long post, but this requires a little back story. I work in a facility with a couple hundred VFDs Most are in a web...
251
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
339
Hi everyone, This is my first time posting, so please forgive any omissions or mistakes. I am attempting to control the velocity of a stepper...
18
1,051
