Encoder Connection
yogesh_n
Aug 2004
MUMBAI
dear all
i want connect omron make encoder(o/p is 8 digit binary) .
should i connect this encoder with A & B'S MICROLOGIX 1000(ANALOG).
PLS GUIDE ME ? HOW I CAN DO THIS.
REGARDS
YOGESH
Is it an absolute or pulse encoder?
If its a pulse, you need to connect it to a High Speed Counter card.
However, the way you describe it, it sounds like an absolute encoder. This should probably be connected through the normal binary inputs. A word of warning, you need to make sure that the bits will not change too fast for the inputs of your PLC.
A few other popular ways of connecting an absolute encoder:
RS 422 (Needs a special PLC input card)
Profibus, device net etc. This would be my favoured method, if the encoded is compatible.
Doug
dear all
i am yogesh nandavikar from india.
i am thinking on one topic smart sensors.
as i understand about smart tx .it has hart signal which superimpose on 4-20mA signal.
as seen in every smart tx. take e.g of pressure tx (smart). it gives 4-20mA according to pressure but the same time it gives temp of applied media but in the digital form. i.e means we can access that digital signal by hart communicator or hart modem.
if i able to get hart signal in my plc .i can control (or manipulate)
pressure and temperature same time.so it will reduce my cost of one tx.
so pls guide me to take hart signal in plc.
regards
yogesh.
Good afternoon! Please help, the following situation happened: Connected encoder Siemens 6FX2001-5QN25 with Profinet IO to PLC S7-1200. The...
1,123
Hi, I would like to connect an encoder to Yaskawa A1000 drive. I have a Open collector type encoder and Yaskawa need line Driver output encoder...
1,033
Hello Every one I am trying to connect the encoder with siemen's 300 plc but dont know how to do it... Could some one send me the connection of...
2,225
I'm being asked to bid a control system using Siemens S7-1500 controllers, which I don't have any experience with. The digital, analog, and...
2,695
Kindly, where can we find the Colors of the wires used inside an encoder signal cable? Any international standard for the Colors used on signals...
995
