encoder omron
juan
Apr 2003
50
We want to know how you can initialize an encoder in his origin position(output z). For the moment we can turn the motor for 360° but there is no zero point(we don't receive pulses on phase z). Phase A and B behave in the correct way. Can anybody help us to correct our mistake?
Check the part number of your encoder. Channel Z is typically an optional feature. You may have purchased an encoder without it. If you should have channel Z, but you're getting no signal from it, then round up the usual suspects; check the wiring to make sure you've connected it properly, check the continuity of the wiring from the encoder to wherever you're using the signal, make sure that the device to which the Z channel signal is connected is not shorted. If all else fails, replace the encoder.
This may not apply here, but certain early versions of the SLC high speed counter card would not accept an input on the Z channel. Whatever hardware you are using may have the same problem. If your encoder does indeed have a Z channel output then a DVM on the output line should tell you whether or not it is working.
I am providing 24 volts on encoder input but getting the 24 volts on encoder output.The output voltage is not changing,so I want to ask what will...
2,353
Dear all PLC's master, I'm trying to connect CPM1A to rotary encoder (Omron E6B2) using PRV with this code (0 0 DM100), but i can't read the...
6,169
Hi All, Need some help regarding MicroLogix 1400 HSC, Can I use Omron Encoder : E6B2-CWZ6C 600P/R... I badly need help.. Thank you very...
4,340
hi i am a beginner, can any one help me to use encoder or a proximity counter to calculate the positioning of belts.
6,658
Help needed, Is there anyone who ever write code for OMRON Rotary Encoder with MicroChip's PIC16Fxxx series. I'm seriously needed. Thompson Soe...
3,460
