Encoder Signal to 2 differnet PLC's
Mark Buskell
Sep 2003
Florida
892
I am using a Control Logix platform along with a 1756-HSC. The
encoder is stricly used for counting pulses. Its outputs 1024 pulses per revolution. The 2 wires are feed into the 2 A0 terminals (5V and return). What I would like to do it take the same signal and feed it into a seperate ControlLogix PLC with another HSC. I am worried about losing pulses if we do this. The pulse count is critical for this machine.
Does anyone have any feedback on doing this or what may be required (signal booster maybe).
I also have to connect pulses to seperate controllers. In order to do that I use solid-state relais form Phoenix-Contact (see attachment).
I also added a circuit diagram.
Is there a need for redundant counting? If not, why not just send the count from the first plc to the second using communication?
Hi all, I have an application coming up where I have a motor that runs forward or backward to adjust the linear position of a machine component...
1,340
I am looking to duplicate a quadrature encoder signal where the original supplies a VFD and the duplicate goes to a PLC. I have had success using...
2,115
I am trying to replace an old Relience system with S7-300. The system has an encoder that uses external 220V supply and has 12V A,A*,B,B*. As...
1,151
Motion control isn't my specialty... Lately, I have been using Automation-Direct servo packages...
3,024
I am trying to use one Encoder for two separate systems. Do you have a suggestion for me? Do you suggest using a signal splitter board instead...
2,813
