Encoder SSI double connection
Kataeb
Jan 2007
www.livelovelebanon.com
636
We have the following absolute encoder on our machine:
Absolute encoder, SSI, supply 10 to 30 vdc, Siemens, 6FX2001-5FS12
Connected to the following module:
Module, CAM, 16 outputs, 24 vdc, s7-400, Siemens, 6ES7 452-1AH00-0AE0
(signals wired: DAT, DAT, CLS, CLS, 24VDC & M)
We need to connect the encoder signals to the following item (to read the machine actual position):
Board, SBM2, absolute encoder evaluation, +connector, Siemens, 6SX7010–0FE00
(Installed in a Converter, motion control, + SBR1 + EB1 + SBM2, Siemens, 6SE7013-0EP50-ZC23+G62+C41)
Should we connect the SSI signals (DAT, DAT, CLS, CLS & M) to the SBM2 board? Or only (DAT, DAT & M)?
Will any damage happen to the SSI encoder or to the CAM module or to the SBM2 board?
It's possible. SBM2 should be parametrised to work with the encoder. The FM452 should be put in the Listen-In mode. In the FM452 manual you can find example of wiring.
As the customer will probably not accept any modification on his machine program (to change the fm452 to listen-in mode), can we do it the other way around (sbm2 listen-in mode)? Note that we are adding a servomotor with a motion control drive to the original machine, and we can do what we want with the drive parameterization.
Hi all, I have an application coming up where I have a motor that runs forward or backward to adjust the linear position of a machine component...
1,334
I'm being asked to bid a control system using Siemens S7-1500 controllers, which I don't have any experience with. The digital, analog, and...
2,685
Hey Guys, I am trying to use an SSI encoder for the first time and having problems getting any data from it. I am using a 1738-SSIM23 Armorblock...
4,025
hi. i have a AB PLC5 communicating to a Control Techniques Unidrive SP via MODBUS. the Unidrive is connected to an absolute encoder via SSI. the...
1,640
Hello to all I have a problem with encoder from bei sensors. encoder is dual with ttl and ssi channels. When i turn off and turn on my system...
3,619
