engineering project using PLC
I Attempted to do the work
I Attempted to do the homework
THEN I Asked my Question
details : i has done lots of project but now my ideas of making project is getting empty ......
1. A "Machine project".
A machine that runs through several sequence steps to manufacture one part.
The program must use a state machine.
The program must have both fully automatic mode, semiautomatic single-step mode, and fully manual mode.
The HMI must display step information, including information about the next pending step.
Settings must be handled by recipes.
Errors must be handled intelligently. Error codes must be displayed on the HMI.
Each manufactured part must be logged to a database.
2. A "Process plant" project.
A plant that consists of many motors, pumps, acuators and sensors distributed over a wide area.
The program must consist of reuasable code objects for each type motor, pump, actuator etc.
On the higher level, a proces control with one or more PID loops controls the actuators to achieve the desired process.
It is possible to split the project into continous process and batch process.
The HMI must allow the monitoring and control of the process on the higher level.
The HMI must allow the monitoring and parameter adjustment of the individual actuator and sensor on the lower level.
Error codes for both the higher level and the lower level must be displayed on the HMI.
There must be trend curves on the HMI for the control loops.
All important process parameters and sensor values must be logged to a database.
If the above is too much to swallow, it can be split into sub-projects.
What the machine or the process plant actually do, your or your students can discuss.
Just curious - I see there are channel configurations for the 5069-IF modules that let me type in the high & low Engineering units as well as the...
1,011
Hello, Has anyone taken the PE Control Systems Exam recently? If so, do you have any reference materials besides the official Study Guide?
1,066
Hi Guys, Just wondering if you can use an Indusoft 8 engineering dongle for Version 7. Trying support is rough!
1,260
Where can i find older versions of Siemens Scout engineering softwares? like the below one? downloads...
1,154
