ENI IP Address
Jan 2007
Humacao
Need help!!! don't know how to download the IP address to a 1761- ENI. I know I have to use a program to do this but don't know where to find it.
Any help will be highly appreciated.
Thanks,
The program that you want is the BOOTP/DHCP Utility. This is basically a DHCP server software that you install on your PC.
Assuming that you have not disabled the BOOTP setting in the ENI module (it is turned ON by default), this should be pretty straight forward.
Sometimes I am using a PC on which the network settings won't allow the BootP/DHCP server to run, or the device has been set to Static IP and I don't know the address, so I resort to the 1761-NET-ENI configuration utility.
The most common gotcha is that the default utility serial speed is 38400 but many of the controllers I use run at 19200. Easy to fix. Also, this utility doesn't work, in my experience, with a USB/RS232 converter.
I was surprised to find that it's gone missing from the proper link on the www.ab.com/micrologix site, but it turned up here:
http://www.ab.com/programmablecontrol/plc/micrologix1000/networkinterfaces.html
Net Eni series D. How do I assign IP address???
2,330
Dont know if anyone can help, been trying to do this all morning. Basically I have a new ENI module that i need to assign an IP address to. I...
11,430
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
161
Good afternoon guys, does anyone recommend a direct replacement part for Allen Bradley's 1761-NET-ENI devices? We have a lot of these in our plant...
1,017
Hi. I am having trouble establishing comms between an slc5/04 and panel view plus 7 via a PLX51-net-eni. The set up is: 5/04 Channel 0 DF1...
942
