EPROM made on SLC5/04 OS401C fails on SLC5/04 OS401B ?
JesperMP
Feb 2003
ᚴᚬᛒᛅᚾᚼᚬᚠᚾ
16,342
Hi there.
I have sent an EPROM to a customer with a minor modification.
Upon installing the EPROM, the CPU fails.
Unfortunately, the customer dont have any programming software to read out the error code, he only reports that the CPU fails with the new EPROM, runs OK with the old EPROM.
Since the customers project is quite old, and I have a fairly new CPU at home to make the EPROM, I wonder if that is the reason.
My home CPU has OS401C, and I think the customers CPU has OS401B.
Anyone knows ?
The plot thickens.
Collegue of mine says that newest EPROM (1747-M13) are incompatible with old firmware versions. This is probably the real problem.
Can someone confirm that upgrading the firmware to OS401C will allow the M13 EPROM to load ?
There is no electrical snafu with old SLC5/04 CPUs and new EPROMs ?
Jesper
Im not sure about M13's or Newer Firmware
But i can tell you that an M11 EEprom burned on a series C will definately not work when put in a series B. They are not backwards compatible.
However if you burn the EEprom on a series B then it will most definately run on a series C.
I had this problem the other day when on site, i was lucky enough to be able to swop out for a series B, burn all EEproms on this and then run in Series C.
And as a side note when i changed the series C program to a Series B processor i got some sort of warning to the effect that data tables would need resizing etc. So this may be why Series C wont run on a Series B processor ? Perhaps Ken can chip in here to explain ?!
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
125
Hi , we try to get a CPU 317T-2 D back to life,memory card was defective and with some resets we have only sf light red flickering we...
28
751
I have a Siemens S7-200 with a bad output. Bought a new processor, PN 6ES7 214-1AD23-0Xb0, to replace it. I have an EPROM Memory Module, PN 6ES7...
815
Hello, I have a one off job to modify some Siemens Step5 software at a local factory. The PLCs are S5-100U (CPU103). I have uploaded the PLC code...
4,311
Dear All, I have an S7 300 damaged CPU. I don't have it's backup program. I want install a new CPU. If I replace the new CPU internal EPROM with...
1,690
