Erase s7-200 memory
mvaughan
Sep 2007
South West Michigan
62
I have an S7-200 that is password protected. Is it possible to totally erase the memory without the password. It is off an old piece of equipment and is available to me if I want it. I have a friend with compatible software I could use to learn Siemens programming.
Thanks,
Matt
If the 200 hasn't been powered up for a while (over 12 days or so) it will lose all of its memory so ou have a blank CPU.
Hope this helps
Hope this helps
i dont think so, for the model i use 6es7 21x xxx23 only the data table modified during runtime get lost when the capacitors inside the plc get discharged after 10-15 days....After then it is the initial configured data that get used with the remaining programme
The way i do reset a S7-200 is with a small programme named wipeout.exe i think i downloaded it from the siemens site back then but i don't remember for sure....
Just an additional note, you can use the default password to allow you to reset/download to the cpu... CLEARPLC
Regards,
Rob
Hello. I'm working on a RSView32 .gfx that was started by a someone who moved elsewhere. There are three yellow lines on the page that I can't...
1,397
I have an old Magelix XBTGT4330 HMI with an existing program loaded and user security set for downloads. How can I wipe this thing out so I can...
4,237
Hi, I have an OMRON CP1E PLC, it already has a program inside however i want to put a new program in it. Is there anything i have to do e.g...
3,649
Is there a command that you can use against a UDT that will fill it with zeros? Of course the UDT has dint, bool and strings... EX: FLL...
11,345
Hello guys Could you please tell me if i do MRST for S7-300 that has MMC from simatic or by cpu switch it will erase programme in Ram only or it...
1,957
