Error in Module S7 CP340
Amoniak
Aug 2014
Legnica
CPU 315-2dp 6ES7 315-2AG10-0AB0
Module:
CP 340-RS232C 6ES7 340-1AH02-0AE0
When I'm using I/O module I'm sending data from DB's to printer ZebraGX430t. Everything was fine, protocols and hardware settings were properly configured, printer was working how it should, data stream was ok... but it was only for a few hours.
Printer stopped working, i checked configuration and prgoram but there weren't any changes. After Cpu reset, printer come back to living annd i coudn't see any problem, but next day situation appeard.
I managed to printscreen errors from module, but i don't know the issue. Aflso added P_Reset block to clean buffer but i'm not sure if it'll help.
Thanks for any ideas.
Errors:
http://postimg.org/image/81qotkbxj/
http://postimg.org/image/3tvwktahz/
81qotkbxj
3tvwktahz
Hi all, I have what is likely a simple problem. My program says when 2 buttons (we can call them buttons A and B) are held for 1.5 seconds...
205
Hi, Maybe someone has an idea or has experience something similar. I have few safety IO output modules (1734-OB8S) installed behind the...
819
Hi I have hms-en2mb-r module . When i configure and go online the module is faulted with error code 16#0009 and addition code 16#0001. Is there...
740
Hello, I am a beginner at Mitsubushi PLC programming. I am using a Q02CPU with some modules attached. I Am trying to move a servo through QD75MH1...
386
Hi everyone, I have this issue with a PowerFlex 755 that it mount a Safe Speed Monitor option module. Frequently, while running, appear the error...
2,393
