Error initializing AssetCentre
celso3093
May 2021
Brazil
17
Hey guys,
I've been trying to configure AssetCentre to backup FactoryTalk View SE. For that, I restored a backup from an application. At the start of the process I checked the option that would copy (or something like that) the FactoryTalk Directory.
I think that checking that option made something wrong in the AssetCentre Client, everytime I try and open it I get the error shown in the print screen below.
I don't know how to fix this. :unsure:
Thank you all
According to an RA Tech Note on this error message your client computer is not connected to the same FactoryTalk Directory as your AssetCentre server. This would of course assume that the Client is running on a separate PC from the server. Is that the case? I guess it is also possible that if it is the same PC that restoring wiped out all of the existing FactoryTalk credentials on your computer.
On the Client PC, run the Specify FactoryTalk Directory Location tool. This can be used to connect your client computer to the same FactoryTalk Directory that your AssetCentre is using.
OG
It's not the case. I'm running both server and client on the same PC.
I'll try to run the Specify FactoryTalk Directory Location Tool tomorrow and see what I get.
Thank you very much
If it is the same PC then that tool is not necessary. My guess is that the FactoryTalk credentials you had on that PC were overwritten when you restored your View SE application.
I would run the FactoryTalk Directory Configuration Wizard. Select Local and Network Directories. When prompted for a User name, enter the user name for the Windows account with Admin privileges. Enter that accounts password. If you have selected Local and Network you will be prompted a second time for the user name and password.
That is what I would try.
OG
OG
I already ran the FactoryTalk Configuration Wizard but I think I selected only the Network. I'll try to run it again now selecting both directories.
Thank you very much
OG
It didn't work. I ran The FactoryTalk Directory Configuration Wizard for local and network directories, it completed succesfuly for both, but the assetcentre client keeps showing me the same error. o_O
Just in case someone is looking at this old thread, The Technote lists 4 causes:
1. FTDirectory
2. Service stuck/stopped
3. Codemeter not working
4. Expired activation
When I got this message, rebooting the server fixed it (FTAC Service had not loaded the Server Activation)
I upgraded Factorytalk activation manager to version 5.01 from 5.00 and since then, Factorytalk Assetcentre stopped working! I receive the...
474
I am running rs linx classic 2.54 on windows 7. When I try to load the rs 232 driver, i get a message saying "error initializing registry" and I...
16,433
HI EVERYONE I am having problem when installing 1747-PIC and I always get this message as title of this thread.Laptop with win xp SP3 and rslinx...
13,062
Hi there, I'm new to plc programming and was wondering why I get this error code when I run my simulation for these temperature sensors? What I'm...
69
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
363
