Error messages in FTVME but looks ok?
DairyBoy
Jun 2007
UK
393
The attached bmp is my runtime comms setup for a PV+1000 application. As far as I can make out it's identical to my previous (and first FTVME) project.
On completing the MER file generation, I'm getting:
[FONT=&quot]WARNING: Unconfigured shortcut detected. Shortcut name = "plc". Description: The system has detected that the noted shortcut has not been associated with a device on the Runtime (Target) tab. If the application makes use of this shortcut, then runtime errors will be detected and logged when the application attempts to use that shortcut.[/FONT]
Must be wood-for-the-trees, but it looks identical to my other project. :unsure:
Go down two steps and highlight the Processor itself, then click Apply to associate the Processor with the RSLinx Enterprise Shortcut.
Even though the Ethernet port is physically "onboard" the CompactLogix, it still uses a backplane object that makes it logically identical to a ControlLogix in Slot 0.
Hello, I am getting similar error messages as in this thread http://www.plctalk.net/qanda/showthread.php?t=110687 Except these error messages...
3,510
Hi Guys! What are the possible causes of Multistate Indicators displaying 'error' messages when test-running application in Factory Talk View ME
1,988
I'm working on an existing system (Historian, VantagePoint, Transaction Manager - just added View SE to the mix). In the message area of View SE I...
10,632
I connected to an Ultra 3000 drive using Ultraware and I am able to monitor the drive for a short time only. After a minute or so, I am greeted...
5,327
Hi all, It's been a long time since I last posted but I'm still around. I'm currently running a septic system control on a 6x4 IO Twido...
4,238
