ET200s Capable of Being master besides using card
Tommycai
Aug 2011
KY
120
Are there any ET200s Modules that are capable of being master and slave without buying an additional card?
I know that with the 151-7 ET200s card you can buy the 6ES7 138-4HA00-0AB0 and make it a master but I want to do it without buying additional hardware
The IM151-8 can be a Profinet IO Controller. It is similar to being a Profibus DP master.
It is not Profibus but Profinet. Profinet is quite easy to configure so maybe it is worth considering.
Within the Siemens S7 family, the lowest cost possible is an S7-1200 CPU with a CP1243-5 DP master module. I have no experience with it though.
Apart from that, if it must be ET200S, an IM151-7 or IM151-8 plus the DP master module is the only possible way.
I was trying to communicate between Siemens ET200S IM-151-8 PN/DP CPU to Rockwell Allen Bradley L73 through Hilscher Gateway NT100-RE-EN. Using...
119
Hi all It’s been a while since I did any safety config with an S7-300 PLC and I think I must be missing something , I’ve added a 4F-DO output...
3,836
PLC in the project that I am currently working on has following GSD file but I cant find it anywhere online. My PLC is ET200S and its CPU is...
2,109
Got a new project using WinCC SCADA (V7.5 SP2) - the PLC is an ET200-SP, I've never had to communicate with one of these before (done plenty of...
2,448
i m working on an old machine that has a layout of 1 cpu 6es7 315-6tg10-0ab0 (bus adresss 2) 1 et200s 6es7 151-1aa04-0abo (bus adress 4) 1 et200s...
3,208
