ET200s Online
Frosty
Jul 2008
Cork
66
Hey there,
Just wondering if any of you may have experience with the ET200s bus in Siemens?
Basically what I want is a bool or value to tell me that the bus is online and running. The reason for this is I have a 1Count5 on the bus and want to turn off the SW_Gate when the bus is offline so I don't return the current count to 0 - then when its back online I load the last value to the counter and enable the SW_Gate again.
I have set up OB100 to load the value to the counter after PLC power up, but the ET200 is powered externally in another machine.
Any thoughts?
Cheers...
Hi Jesper,
Once again you have solved my Siemens issue - Thank you very much.
FYI the ET200s was on Profinet.
mange tak
I was trying to communicate between Siemens ET200S IM-151-8 PN/DP CPU to Rockwell Allen Bradley L73 through Hilscher Gateway NT100-RE-EN. Using...
118
Hi all It’s been a while since I did any safety config with an S7-300 PLC and I think I must be missing something , I’ve added a 4F-DO output...
3,831
PLC in the project that I am currently working on has following GSD file but I cant find it anywhere online. My PLC is ET200S and its CPU is...
2,099
Got a new project using WinCC SCADA (V7.5 SP2) - the PLC is an ET200-SP, I've never had to communicate with one of these before (done plenty of...
2,435
i m working on an old machine that has a layout of 1 cpu 6es7 315-6tg10-0ab0 (bus adresss 2) 1 et200s 6es7 151-1aa04-0abo (bus adress 4) 1 et200s...
3,208
