Et200s Si Serial Coms
hein123
Aug 2010
Uitenhage
93
Hi, it is me again :)
I have a Et200s serial module and seem not to get any communication when I connect to the Hercules (similar to Hyper Terminal).
When I send data to the module via S_RCV, the PLC reads the data. However when I send date via S_Send I read nothing
Any advice?
I am using a cable I always use for testing.
I am only connecting Tx and Rx and GND as the Marker I am using does only have this option. This cable goes straight from my PC to the interface card as I firstly want coms to make sure this card works.
Data does get send via the S_SEND block as I do get the Send bit. However I don't read anything. No problems with the receiving side.
What else can I try?
Do you see if the TX Led is flashing on your 1Si module.
Also a very common misstake is the connection of the cable.
pin 1 and 5 for RS232
pin 1 and 2 for RS485
If using RS232 ensure you connect the GND to pin 8 of the 1Si module so the communication partners refer to the same signalling levels.
On your S_SEND block ensure you assign correct values to the inputs. DB, DBB and LEN must be given correct values.
Hi, I need to test a scanner connected via RS232 / ASCII on a ET200S 1SI CP card. After downloading the hardware configuration I have fault leds...
1,377
I was trying to communicate between Siemens ET200S IM-151-8 PN/DP CPU to Rockwell Allen Bradley L73 through Hilscher Gateway NT100-RE-EN. Using...
116
Hi all It’s been a while since I did any safety config with an S7-300 PLC and I think I must be missing something , I’ve added a 4F-DO output...
3,830
PLC in the project that I am currently working on has following GSD file but I cant find it anywhere online. My PLC is ET200S and its CPU is...
2,093
Got a new project using WinCC SCADA (V7.5 SP2) - the PLC is an ET200-SP, I've never had to communicate with one of these before (done plenty of...
2,430
