Ethercat on Step7
Manglemender
Jul 2007
Lancashire
1,295
Can anyone offer advice on connecting EtherCat devices to S7-317-PN/DP PLC?
We have 8 devices being built into a machine (free issued) that have an Ethercat interface and sooner or later someone is going to ask "can we connect them to the PLC?"
I've come up with two thoughts so far:
1) anybus module but I think I would need a master for 8 slaves
2) Vipa Speed7 CPU with Ethercat master acting as go between.
Any thoughts or advice?
Nick
I'm also using Beckhoff EK9300 I/O with a Siemens PLC system and I was wondering why the EK9300 has its own I/O area even when there's no I/O cards attached to it. Is this normal for Beckhoff? Can I free up that I/O area or do I just have to live with it? Thanks!
I have an Omron NX PLC NX1p2 which Supports EtherCAT . also I have Balluff BNI00HA Ecat Block(IOlink Master). I have setup communications and...
167
If an IPC with Codesys runtime on it has two separate ethernet ports, is it possible to have an Ethercat master on each of them? I do not find...
534
Hello everybody. I encountered a problem - I don’t know how to update the firmware on the Mitsu MR-J5-40G-N1 (ethercat) servo amplifier. My...
403
Just curious if anyone has been down this road before? Considered using one of the anybus gateway adapters, experience with them. Master...
665
Afternoon all, So, i have an output that is being fired from 2 inputs separately. 1st input is a sensor, when something passes by it should...
323
