Ethernet I/O newbie
JeffKiper
Jun 2006
Indiana
2,462
Guys and gals I got asked to add some IO to a Compctlogix. My first thought no big deal until I saw the panel. Packed full of stuff so adding phyical IO to the local chassis is out. The processoris a 32L already on Ethernet. Can anybody recommend IO for this project? It will be a mixture of Analog and Digital. I have never used E-net IO before so I am open to any advice or warning from the Old Pros out there for a young buck.
Thanks for you time.
JAK
I just finished up a job with Flex I/O using ethernet and ControlLogix and it worked without a hitch. Straight forward and easy to setup, and good for restricted panel space as you can connect right to the TB3 (eg) termainal blocks.
Try Point I/O or Flex I/O from Allen Bradley. I use them in several areas on a control logix system. It should work for compact logix as well
You didn't mention how many I/O you need. If it is just a few you may want to consider going to 16 point analog modules or 32 point digital modules.
I had not even thought about using Flex. I have flex all over this plant using RIO, C-Net but no E-net yet. It sounds like a great idea I am going to look into it thanks for your help. I will let you all know what happens with it.
Look into the 1794-AENT module. Replaces the 1794-ASB that you're used to for RIO.
The last time we tried to buy 1794-AENT modules, we couldn't get them. Apparently Rockwell was having problems with some of their components. Ended up doing the job with FlexIO and DeviceNet -- that got a bit ugly!
If you can get the AENT's now, that's definitely the way to go.
Flex I/O look like a great alternative for use I am in the middle of researching it now. If it is as good as the rest of the flex stuff I think we will be OK.
Guys and Gals I do appreciate your time. Thanks I will let you all know how it went and hopefully I can make it threw this project without bothering you all.
Hello, y'all! In order to connect the control network from a central room, what version of FT should be used on the PCs? Thank you very much!
2,216
Hi, I need to connect 3 CompactLogix PLCs and 3 touch screens, and have remote access to them from a PC. I guess that I will need an 8 port...
3,699
179
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
96
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
312
