Ethernet Modbus+ over Radio 15 Miles too much?
MesquiteThorn
Jan 2011
Texas
Can ethernet radios reliably handle 15 miles? Flatter than a pancake (mostly across a Bay), clear line-of-sight.
WHOA--Stop. The remote units (140CPU311 10) do not have an Ethernet port. Just 2 Modbus and 1 Modbus+. The master is a 140CPU651 60.
So how about Modbus+ over radio/ 15 miles?
The project has a one master and 6 remote Quantum PLC's. I inherited the project from a diff eng firm and the client who bought the equip has retired. We are replacing some Bristol RTU's. They were doing a replace in kind. The Quantum's can handle the Modbus comm through radio modems with the XXMIT FB, but it is very cumbersome and antiquated. All we are doing is Read/Writes to register between the master and remotes.
check out the mds inet. should be able to handle 15 miles as long as you have a clear line of site and the right height on both ends. you can also check out freewave. I think they will also run the path profile for you to make sure it would work.
I see that you just need serial connectivity. both of those manufacturers make serial options also.
Does anyone have any recommendations for Electronic Circuit Breakers with 0V Terminals built-in and Fieldbus (IO-LINK, MODBUS TCP, EtherNet/IP?)...
204
What's the cheapest way to go from modbus rtu rs485 to Ethernet IP or TCP. I've got some power transducers I'd like to read some modbus addresses...
1,370
Hello, Sorry, my knowledge of communication protocol is limited, so thank you in advance for your answer. My question; I want to get 5 values...
869
Hi All, Trying to help a client who has a project that was started with Schneider STB remote I/O, but they are still waiting on the STBNIP2212...
1,926
Hello all, I was wondering if you clever people could help me, please. In the past I have used a standalone L33ER CompactLogix PLC with the...
1,542
