Ethernet Module EWEB/A CompactLogix L43
italo2008
Feb 2009
Padova
95
Hello
I'm trying to configure an Ethernet/IP module for establishing a communication between my PC an PLC. The problem is that RSLinx says that the IP address of my LAN card (Realtek RTL8139 Family PCI Fast Ethernet NIC) is unknown. I have set a static IP address (192.168.0.1) and a subnet mask (255.255.255.0) in the control panel but I still have this problem. In addition, when I digit ipconfig/all in the command prompt, in corrispondence of the Lan card, there' no IP address. How can I solve this problem? (sorry for my English....)
Environment: ControlLogix 1756-L61 with an EWeb card. Trying to send a byte to a remote host via TCP. Creating socket - success. supply...
2,291
Hi all. I'm having issues adding an ethernet module to my project in Studio500 v34. The device is a Fredericks Televac EthernetIP MX gateway which...
387
Hi, I am trying to set the IP address on the IC200UEM001 Ethernet Option Module. I am following the procedure in the manual for setting a...
441
Hi. Rockwell learning curve 132-1b. I was having trouble to change IP address on a EN2TR. Finally found out that I need to change the IP...
865
Hello, We are having trouble setting up a generic ethernet module for a Yaskawa GA80U4168 drive in RSLogix 5000 Version 20.01. All of the...
631
