Ethernet remote I/O for all PLC's
geniusintraining
Jun 2005
SC
8,277
I am building a digital remote I/O station and will need to communicate to several different PLC's via Ethernet the station will have several inputs and several outputs, maybe analog also, this will only communicate to one PLC at a time.
The PLC's are ControlLogix (ENBT), MicroLogix (1400), GE 90-30 (CPU 374), Mitsubishi Q06HCPU (QJ71E71-100), Siemens 1215, Omron, Schneider, WAGO and Click
I have never used one and have found a few, has anyone ever used the Red Lion E3?
http://www.redlion.net/product/e3-io-module-34-mixed-inputsoutputs
If you have used one and like it let me know the brand so I can look at them
Many thanks!
hi genius, how did this project go? were you able to make clx and mitsubishi talk to each other without using redlion?
Hello,
We ended up using the Red Lion, I tried a couple of different protocols but from what I heard the school that we sold it to has used it for many, Red Lion has a good reputation of being able to communicate to just about anything
This is the one we made for the school, they are teaching the different protocols
Not sure I have not used that one, not sure about the price either, lets put it this way.... Red Lion is very proud of their product the list price is about 1000 USD, but it does a lot
Hi Genius, I believe a lot of the PLCs you mention talk over Modbus TCP/IP as well, being an open protocol. The Red Lion E3 you chose for the application looks to be an excellent product for the application . Some food for thought, another inexpensive solution is using EZAutomation EZRemote I/O that talks Ethernet I/P and you can put various I/O modules on it (DC, Analog, Temperature etc.)
http://www.ezautomation.net/ezremoteio/ezremoteio_menu.htm
Hi there, I have an application where I’m required to connect Siemens S7-300 PLC (Profinet) to Allen Bradley Control Logix Remote I/O Rack &...
3,659
This question is about PLC Schneider Momentum M1 171 CCC IEC-960-30. We have one output element ADO 710 50 attached to the PLC via...
3,286
Dear all, I need to make a control system and I don't know what PLC to use. The system consists in: Control of 10 digital...
2,482
Hi All, Trying to help a client who has a project that was started with Schneider STB remote I/O, but they are still waiting on the STBNIP2212...
1,916
Does the last octet mean anything? Technically the network's address is 0, but why does it give you the option in the first place?
1,585
