Ethernet Status
widelto
Jul 2005
Barranquilla, Colombia
3,392
Hi folks:
This is new to me, this is the first time that I am using Allen Bradley
5069-L310ER CPU, in my case I am planning to use the two ethernet port separate, i.e. they will have different IP addresses.
Please see my attached figures, I want to get ethernet status from each ethernet port separatedly, but I see no way to differentiate one port from the other.
When trying to use Path there is only one option (port)
Have anyone tried this before.?
I am using Studio 5000 V30.
KB 900835 (TechConnect level) describes messaging in dual ip mode.
Port A1 Example: 3,IP_of_L23E,1,0
Port A2 Example: 4,IP_of_L23E,1,0
Noice!
I actually have a project it the pipe with one of these so I'm glad you asked this question here. +1 knowledge points!
In some communications with a Micro 820 I'm seeing a General Status Code of hex CC decimal 204. My CIP spec is pretty old and it lists that range...
2,789
Recently we've had some faults and disconnects with our 1734 aent/r module. It shuts down all processes associated with the remote IO, obviously...
3,357
Is there an easy way to basically "ping" various ethernet nodes in RSlogix? I have a small automation cell with various cameras and barcode...
1,664
Hello, I’m communicating a ControlLogix 5000 with a Yaskawa A1000 drive, via a Ethernet 1756en2tr module. I installed the drive interface as a...
3,106
Hi, I have am working on a project to automate a mine site. There are a number of PLCs with EN2Ts, EN2TRs and ENBTs. I am trying to write an AOI...
2,915
