Ethernet TAP & Profitap
grnick50
Nov 2010
Ptolemaida
332
Hello all,
I am looking for a reliable and sensibly priced TAP to monitor Ethernet traffic with wireshark.
Mainly I want it for non-realtime ethernet, but realtime (Profinet) would be a plus too. I
saw this TAP in Amazon but the comments were not very good. I then came across ProfiTAP but it looks pricey.
Can anyone suggest a device? Has anyone used ProfiTap. What is its cost?
Regards
Some more options - but for realtime analysis you should probably invest in better tools as timing WILL be affected as you pass this copied traffic into your PC.
1. Small USB-powered port mirror device. Simple, easy to power with a laptop on batter (no wall wart). No config, just plug and go - $US80
https://www.amazon.com/Dualcomm-DCSW-1005-Powered-Ethernet-Mirroring/dp/B002BSF112
2. Small switch that does port mirroring. Cheaper - $US30, but requires some simple config. Need AC adapter. Netgear makes the same thing for a little more money.
https://www.amazon.com/TP-LINK-Giga...id=1476526722&sr=8-14&keywords=tp-link+switch
3. Small router device that does port mirror, maybe something like this:
https://routerboard.com/RB951Ui-2nD
Pricing is good, but steep learning curve. Much more capable - can route, has a firewall, packet generator. Lots of built in tools.
4. Special tap - like you reference. I would like a profitap too. Do not recommend this: http://www.fte.com/products/NetworkTap.aspx
which is similar. Doesn't really work the way we need it to, and when I called support I was not convinced they knew what Ethernet and TCP/IP is. Not good for a company selling network diagnostic equipment. I heard good things about the profitap.
Hard to beat the USB powered device for portability even if it costs more than some of the other options.
Hello PLCS.net! I was wondering if there is such a thing available that connects inline with two RJ45 jacks and lets me know what communication...
2,413
Hello guys i'm working with an s7 1200 plc with an ET 200S expansion module. The problem is that i can't find the plc when searching in the...
34
205
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
104
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
321
