Ethernet to DH 485 interface
tcarnes
Jan 2010
Denver,Colorado
Have an existing Allen-Bradley DH 485 system with 5 SLC 5/03's. New blower came with Micrologix 1100. The RS 232 port on the Micro is used for a HMI panel leaving only the ethernet port available to hook to the network. Has anyone found a DH 485 to ethernet converter that would work in this situation?
Have you look at the AB 1761-NET-ENI? Not sure if it does what you want, But I use it to communicate to a SLC503 over ethernet and it works well.
Mickey- Thanks for the link. Would still like to know if anyone has successfully done this.
RDS- Thanks but the NET-ENI doesn't have DH 485 capability.
SLC 5/03 has DF1 and DH-485 ports. If you're not using the DF1 ports, connect them to 1761-NET-ENI modules and run Ethernet cable from them to a switch near the ML1100
Dear, I have to communicate my SLC 5/04 CPU channel0 ,configured as DH485, i have an ethernet interface 1761 NET ENIW. I have read how to...
3,924
I'm using a Lantronix xPressDR+ for serial to ethernet to serial encapsulation to an RS485 ASCII string of instruments. The software part...
1,923
I need an adapter for Ethernet to RS485 ASCII traffic. I found a couple cheapos and bought them but all the docs were in Chinese and I just...
1,838
Hey all, long time reader but first time poster here. I've been tasked with an odd one and was wondering if anyone else had experience in this...
17
5,354
Hi, I have PanelViev 1000 grayscale and SLC5/03. I run SCADA via ethernet bridge that is connected to SLC5/03 via RS232. The PanelView is...
4,443
