Example Control 2 Pumps by PLC & real program
Platootod
Jan 2003
Mechatronics RIT.Non
215
Here is some pictures about 2 pumps control with plc ..include real program .
This picture has shown ..Testing by program before
installation at the real place.
Here the program (GX developper Version8)
Here is the real program that I use in this project
PLC MItsubishi FX2C with Gx Developper Version 8
(can export to FX format)
This is some example of SFC program
This project was written by me with SFC (Sequencecial fungtion chart)
and the program that I have post is a real program.
Here is more picture with control valve & pressure sw.
Almost input & output signal of PLC has cross check..
for example output No.1 control the Contactor Pump No.1 ..
bring Aux. contact (Contactor Pump No.1 ) to be another input of PLC..
After start Pump No.1
check pressure Sw. for 30 sec...if the presure not reach to set point
or no pressure then stop Pump1 and start Pump No.2
If you use program Gx Devellopper version 8 , you will know the process from the program that I have post.
:oops:
I'm not a PLC programmer but I am developing a control interface (to run on a PC) for a "device", to be used by a PLC. I created a...
26
5,780
does anyone have an example of this in a Contrologix FBD? This is my first time having to program one and I want to make sure that I am on the...
2,589
Hi guys, after some time (I was busy passing exams) I'm back to PLC programming. I'm trying to write a simple ladder program to control a garage...
4,727
Hello people! Please, I would need examples on how to program with wonderware's InControl. Does anyone have any example to share? Thanks in...
2,276
