exeed dicitionry limit
albarasi
Dec 2016
libya
if start project form intouch application coming massege exeeded dictionary limit of 500 tags- exiting ...... how can resolve problem
thanks
Not used Intouch for many years but it sounds like the license you have is only for 500 tags so probably needs upgrading to a larger tag license.
Very often Scada type packages are based on number of tags some examples are 512 , 1024, 8,000, 16,000 32,000 or unlimited.
And are priced accordingly.
Good day: I am wondering if anyone has experience with the Kinetix 5500 S33 Fault. I have 3 drives in a group set as follows: 2198-H025-ERS2...
87
Hello, I have a motor that we are sending a RPM Speed Output from 0-100% to the VFD. However, the Motor HP needs to be limited to 6000 HP and the...
106
Hello, I have a quick question. I have been using scripts to change the color of buttons. The reason, I am usually using multiple hmiruntime.tags...
126
Good evening all! I hope you folks are doing alright today, as I've got a situation that I believe I've come up with a solution to but I wanted to...
469
Dear Experts, I'm just started working with GEO SCADA and I need your valuable help. Currently, I'm trying to edit the alarm limits on MIMIC...
224
