Exor HMI panels
maintpro
May 2003
Osceola, IN
28
Does anybody have experience installing the EXOR eTOP50 or the eTOP40 panels into systems operating with an A/B SLC5/02 or 5/03 plcs?
I am currently looking to install the eTOP50 into a system operating with a SLC5/03 and the eTOP40 into a system operating with a SLC5/02. I am just curious of any issues that may arise or precautions that I should take during installation and programming.
Your input/comments would be greatly appreciated.
I haven't used those exact models, but I've used a bunch of EXOR HMIs with SLCs. I usually use the DF1 protocol on a dedicated serial link for the HMI and don't have any problems. On a few projects we've used the EXOR on DH-485 and this works well too. We usually use an AIC+ module between the ESCOR and the SLC. The only drawback is the screen updates are slow, and it may take a few minutes after a power cycle for the HMI to get hte token and start communicating.
Currently I’m using ESA model VT155W0000 HMI and it’s communicate with Fanuc PLC. Can any one suggest can I convert ESA model to EXOR HMI eSMART07M
88
I want to program an Exor HMI using a Rockwell controller. However, when exporting the tag list from the controller and importing it into JMobile...
125
Imported in 19828 tags from an S7-414 into the JMOBILE software dictionary. This hen allows you to pick tags to activate (read/Write from) but...
630
Hi, I have to replace an old Exor Tline HMI with a siemens HMI. I was able to upload the project from the HMI but it appears to have not uploaded...
1,232
Do any of you have any experience comments about the above HMI. It is connected to a Mitsubishi FX2N plc. I have to alter some PLC code and...
4,835
