nmontev
I have a Wonderware In-Touch Application that exports an In-Touch trend to a .csv file based off of an operator action. This is accomplished using Wonderware's HistDat.exe. It basically takes the pens associated with a particular trend and reports the values back to a .csv based off of an operator defined sample rate. This works fine.
I would now like to duplicate the above function in a RS View ME application. From the searches I have completed, there does not appear to be a Rockwell solution to this problem. Is there away in RS View ME to dupplicate the export mentioned above? If there is, could you point me to some information that would describe how to accomplish this?
I have found some threads that discuss how to accomplish this using VB code, I was just looking to see if a Rockwell solution exists.
